> Where can I buy a Type-IV "stroker" crank?
Charles Deutsch
post Sep 16 2003, 11:21 AM
Unregistered
Scat quoted me a price of $1499 for a 78 mm, one piece chromoly billet, T-4 crankshaft and I can buy one from Aircooled.Net for $500 but are there any other places that I can check for prices?
Thanks.
Charles Deutsch
post Sep 17 2003, 09:05 AM
Unregistered
QUOTE(john rogers @ Sep 16 2003, 07:15 PM)
An item that is easily overlooked is the rod length if you are building a stroker engine. If the stroke goes up the rods have to get shorter unless you move the barrels and heads away the same amount as the stroke increase. The "short rod" problem can result in  much higher loads on the small end and can result in even the end of forged rods pulling loose. Seems this used to happen to off-roaders for years until the problem was solved. Good luck.
I keep reading this but it's not intuitively obvious to me that piston speed decreases as the length of the connecting rod increases so I tried to do the math. The equation I get for the position of the connecting rod small end as a function of the angle of rotation of the crank, a, the crankshaft throw, T, and the connecting rod length L is:
x = T* Cos[a] + L*Cos[ArcSin[T*Sin[a]/L]]
then dx/da and d^2x/da would be
Charles Deutsch   Where can I buy a Type-IV "stroker" crank?   Sep 16 2003, 11:21 AM
tat2dphreak   AC.net is usually the cheapest place... most other...   Sep 16 2003, 11:28 AM
john rogers   Two sources are Pauter in Chula Vista CA and Autoc...   Sep 16 2003, 11:39 AM
Brad Roberts   The Scat is ONE piece and not a stock welded crank...   Sep 16 2003, 11:41 AM
Charles Deutsch   How good are Demello cranks? I see they sell 78 mm...   Sep 16 2003, 12:07 PM
Brad Roberts   Damn it.. I knew I should have bought that used De...   Sep 16 2003, 12:11 PM
tat2dphreak   I would also ask Jake... see where he gets his(or ...   Sep 16 2003, 12:20 PM
bernbomb914   Is there a reason that porsche limits its stroke t...   Sep 16 2003, 12:26 PM
Gary   Formula for displacement is piXradiusXradiusXstrok...   Sep 16 2003, 01:39 PM
Charles Deutsch   Next week I'll probably order the Engine Analy...   Sep 16 2003, 01:53 PM
Aaron Cox   berman vw sells them. they have some w/ vw journal...   Sep 16 2003, 05:53 PM
tat2dphreak   read shoptalk before buying anything bergmann... i...   Sep 16 2003, 07:53 PM
Korijo   Demello. Thats what I'm getting. 78 w/ Chebb...   Sep 16 2003, 08:59 PM
john rogers   An item that is easily overlooked is the rod lengt...   Sep 16 2003, 09:15 PM
Brad Roberts   John.. Have you played with Rod ratios for the ty...   Sep 16 2003, 11:42 PM
Brett W   Check out DPR I have heard nothing but good stuff ...   Sep 17 2003, 07:45 AM
Charles Deutsch   Thanks for the great info.   Sep 17 2003, 08:46 AM
Charles Deutsch
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 04:11 AM
