'74 2.0L Rebuild, Looking for advice |
mangrum |
Sep 10 2003, 09:22 AM
Member Group: Members Posts: 180 Joined: 10-September 03 From: Ann Arbor, MI Member No.: 1,134 |
Just about to drop the motor and trans on a '74 2.0L to rebuild the motor, and will be posting questions along the way. Thanks in advance for all who reply.
First things first. What advice do you have for cleaning the outside of the motor and trans? Any chemicals I should use or avoid? What prep work do I need to do first (eg, to protect sensitive parts)? Thanks. |
mangrum |
Sep 17 2003, 12:10 PM
So far it looks like brake cleaner, wire brushes and elbow grease. I was hoping for an easier solution.
I've heard that the heat issue with easy off can be solved by putting it outside in the sun. This could be hard to do with the gray days of winter here in Michigan approaching. My worry with easy off is that there would be some undesirable chemical reaction. Ovens have porcelain interiors whereas the trans is aluminum alloy. Correct? For the cooling tin I was thinking of removing all rubber and taking to the local machine shop to have it baked. Is there a better, more cost effective way? I have access to a sand blaster. Should I have the tin baked first? Speaking of heads... What can I have done to the heads to increase power and improve longevity? I don't want to drop another valve seat. Keep in mind I will NOT be converting to carbs. Thanks. |
Lo-Fi Version | Time is now: 18th September 2024 - 07:17 PM |
