NPC: Transmission "rebuild" - how to clean?, motorcycle tranny |
Michael Oberg |
Apr 2 2006, 07:00 PM
Sausage suit contingent Group: Members Posts: 14 Joined: 27-June 03 From: Boulder, CO Member No.: 867 |
I recently pulled apart my '59 Ural M-72 motorcycle transmission to fix a pretty bad leak (was missing an o-ring). There is quite a bit of sludge build-up on the bottom, and I was wondering what is the best way to go about cleaning and re-lubing the transmission before I reassemble? I have several varieties of degreaser, but I am worried about the rubber seals and bearings that are already in there. I would like to find the easiest way to quickly clean it, without having to dismantle it completely (ie remove the currently working and unobtainable seals, and removing the bearings).
Would it be safe to use a degreaser and then just lube everything up with gear oil before I reassemble? Would it be safer to not worry about cleaning it for now (rest of internals are fairly clean)? Inquiring newbie minds want to know! Thanks for any suggestions. - Michael |
SirAndy |
Apr 2 2006, 10:57 PM
Resident German Group: Admin Posts: 41,971 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
actually, i'd say "brake" cleaner ... get a case of brake cleaner and use it generously. make sure you are in a well ventilated place when you do so. it'll take all the sludge right off it. it's also safe to use on rubber, but *not* plastic ... for assembly, lube parts and o-rings and such with whatever transmission oil you're going to use later on ... i have done many bike transmission in my dirt-bike racing days ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
Lo-Fi Version | Time is now: 14th January 2025 - 05:45 AM |
