| Mueller |
Jan 21 2005, 01:53 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
The cost of aftermarket throttle bodies is way up there, the bottom of scale we have the CB Performance units which are about $250 each and the rest are easily 2X that about.....
so I swung by the motorcycle salvage yard in Fremont today and picked up these beauties (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) 45mm at the butterfly....they taper down to 42.5mm at the bottom... includes a nice TPS and injectors...I doubt the injectors flow enough, but who knows, I'll find out once I get the specs.... no idea of what bike they came off of yet.....price was $125 top view: Attached image(s)
| JmuRiz |
Apr 3 2006, 08:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,605 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Sweet, was waiting on a update for this, looks good.
Mueller New project:Adapting motorcycle Throttle Bodies Jan 21 2005, 01:53 PM
Mueller and a view of the bottom of the assembly: Jan 21 2005, 01:53 PM
rick 918-S Dude! http://www.914... Jan 21 2005, 01:55 PM
Mueller
Mueller it's lunch time now, no need to hide my projec... Jan 21 2005, 02:34 PM
Mueller opps...here is a picture: Jan 21 2005, 02:35 PM
DNHunt Mike
Are those grooves in the TBs for O-rings. M... Jan 21 2005, 02:42 PM
Root_Werks Using bike TB's like this is a great idea real... Jan 21 2005, 02:54 PM
SLITS I have a TB on my 2.0 that is definitely not stock... Jan 21 2005, 03:03 PM
lapuwali
Mueller ... Jan 21 2005, 03:50 PM
Jake Raby I have done this twice! It works...
That size... Jan 21 2005, 04:05 PM
Travis Neff can't you also get TB's with slide valves ... Jan 21 2005, 04:28 PM
bondo Mueller: What are all of your projects? You seem t... Jan 21 2005, 04:43 PM
rdauenhauer So mike are you considering breaking up the bank a... Jan 21 2005, 04:46 PM
Stephane Those look good. What type of injection system are... Jan 21 2005, 04:46 PM
rick 918-S http://www.914world.com/bbs2/ht... Jan 21 2005, 09:44 PM
Mueller Just got back from the local cycle shop...found ou... Jan 28 2005, 05:03 PM
rick 918-S You should just use the whole Ninja motor! <... Jan 28 2005, 06:32 PM
Qarl I think the throttle bodies butterfiles connect to... Feb 4 2005, 12:30 AM
Qarl More good info here...
http://forums.pelicanparts... Feb 4 2005, 12:36 AM
Qarl SO??? Who's gonna do it? Feb 4 2005, 09:36 PM
Mueller played with the TB's a little over the weekend... May 24 2005, 03:36 PM
Mueller adapter ideas: http://www.91... May 24 2005, 03:39 PM
Mueller adapter 2....
this one would have a counterbore f... May 24 2005, 03:42 PM
Randal Nice designs Mike.
Those look much shorter th... May 24 2005, 03:56 PM
Cloudbuster Adapter one! Go with what the factory did.
H... May 24 2005, 03:58 PM
Aaron Cox rubber:
well they use rubber boots on turbo setup... May 24 2005, 03:59 PM
Mueller
Mueller
Mueller
Aaron Cox these going on the turbo motor or the stroker? May 24 2005, 04:15 PM
jhadler Hey Mike,
Those Wakisaki throttles look great... May 24 2005, 04:25 PM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 14th December 2025 - 05:17 AM |
