r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I would like to get a classic thread here...so please lets keep it focused.
With a string box, please describe the process for doing a 4 wheel alignment in the home shop.. To set up a string box, I do the following. Using either milk crates, cinder blocks, or jack stands... Create a rectangle of string around the car. Measure from the centercap of each wheel to ensure that the box is parallel to the sides of the car. It does not have to be square, nor does it have to line up with the front or rear of the car. The string lines need to be parallel, and have the same distance from each wheel center. the string should be at the same height as the centerline of the wheel. Once the box is set up, you can measure from the front and rear of each wheel (not tire) to the string, write these numbers down for each tire. The steering wheel must be straight and lines up as you would like it to drive...for those of you that have a wheel that is already cockeyed...turn the wheel to where you would like it to be when driving straight... Now with all your measurements, you need to adjust the wheels so that the front of each wheel is 1/16th of an inch longer measurement from the string than the rear of the wheel. This will give you an overal 1/8 inch toe in. If you steering wheel is not straight, you will need to fix that first. To change the toe in the front, you will loosen the locking nut on the tie rod, and turn the tierod either in or out...this will set the front toe...if you need to fix the steering wheel position, you basically need to loosen one tie rod, and tighten the other..all the time you will be getting up to check the steering wheel location. that is the front, dont forget to tighten the locking nut when you are done. Now the rear...I am a bit foggy...so someone please describe setting toe in on the rear. Rich |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
since front and rear track are different, side strings that are the same distance from all centercaps will not be parallel. the strings *should* (but not must, it's just easier...) be the same distance from front centercap, side to side, and rear center (tip of the stub axle is okay...) side to side. if possible, measure diagonals; if the side strings are parallel, the diagonals will be identical.
Lo-Fi Version | Time is now: 29th April 2025 - 09:22 PM |
