Monday, 7 April 2025
> tranny drain plug stripped, what to do
drewvw
post Apr 3 2006, 04:52 PM
new england car guy
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil.
Questions:
1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades.
2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out??
Thanks in advance...
drew
drewvw
post Apr 4 2006, 08:18 PM
new england car guy
Noted. This is an ongoing argument I've had wth my dad for about 10 years now. I've always been an "idler", although I'm not delusional that its any better than any other method.
Maybe its psychological, but I've been pretty lucky with cars over the years so I'm sticking to it (knock on wood!)
drewvw   tranny drain plug stripped   Apr 3 2006, 04:52 PM
lapuwali   The spring and ball bearing bit has quite a few pa...   Apr 3 2006, 05:02 PM
drewvw   when I took out the detent plug, the car was in fi...   Apr 3 2006, 05:12 PM
bondo   With the shift fork shafts in place, the other bit...   Apr 3 2006, 05:20 PM
wbergtho   I had a similar problem w/ my drain plug on my 915...   Apr 3 2006, 08:27 PM
drewvw   That was you, I read that post about the welding i...   Apr 3 2006, 08:35 PM
Dr Evil   Magnesium will not stick to the magnet, Bondo. I...   Apr 3 2006, 09:46 PM
Aaron Cox     Apr 3 2006, 09:47 PM
SLITS   I used a chisel and BFH...it came out.....I put th...   Apr 3 2006, 09:50 PM
Dr Evil   ...   Apr 3 2006, 10:14 PM
Cap'n Krusty   Why change the oil at all? It doesn't wear ou...   Apr 3 2006, 10:29 PM
Dr Evil   Don e it many times with a propane torch. Never a ...   Apr 3 2006, 10:31 PM
bd1308   so you CAN torch a mag case? cant weld it though....   Apr 3 2006, 11:04 PM
Tobra     Apr 4 2006, 12:18 AM
Porcharu     Apr 4 2006, 12:40 AM
drewvw   The tranny isn't making any horrible sounds, b...   Apr 4 2006, 09:39 AM
Cap'n Krusty     Apr 4 2006, 09:48 AM
Mueller   the cap'n is correct.....many manufactures of ...   Apr 4 2006, 10:28 AM
Tobra   As I said in my original post, regardless of facto...   Apr 4 2006, 04:22 PM
bondo   It also fills with brass and molybdenum bits which...   Apr 4 2006, 05:39 PM
SLITS   Synthetic leaks out faster........ ...   Apr 4 2006, 06:47 PM
drewvw     Apr 4 2006, 07:52 PM
bd1308     Apr 4 2006, 08:15 PM
drewvw   Noted. This is an ongoing argument I've had w...   Apr 4 2006, 08:18 PM
bd1308     Apr 4 2006, 08:21 PM
drewvw   Yeah but I've driven old european cars with lo...   Apr 4 2006, 08:25 PM
bd1308   I recall someone saying it was in the manual...and...   Apr 4 2006, 08:28 PM
TimT     Apr 4 2006, 08:33 PM
drewvw     Apr 4 2006, 08:37 PM
Tobra   Why on Earth would you sell an S2K? I want one, c...   Apr 4 2006, 08:55 PM
drewvw     Apr 4 2006, 09:07 PM
Tobra   Too bad, I want one of those when the integra dies...   Apr 4 2006, 09:10 PM
drewvw   it was time...I had it for 3 years and started rec...   Apr 4 2006, 09:14 PM
Porcharu     Apr 4 2006, 11:52 PM
racunniff   I ran into this problem - but it was the *fill* pl...   Jan 7 2008, 08:30 PM
Danny_Ocean   Can you drill out the plug with a slightly smaller...   Jan 7 2008, 08:50 PM
racunniff   Can you drill out the plug with a slightly smalle...   Jan 7 2008, 08:52 PM
Dr Evil   I may have a spare plug for ya. You can get a 17mm...   Jan 7 2008, 11:05 PM
Blood red 914-6gt   I may have a spare plug for ya. You can get a 17m...   Jan 7 2008, 11:08 PM
jd74914   but Snap-on is ridiculously expensive . . .   Jan 7 2008, 11:20 PM
Blood red 914-6gt   But worth every penny :D When I was wrenching a fe...   Jan 7 2008, 11:34 PM
Rusty   This thread is a blast from the past... Nice pi...   Jan 8 2008, 06:23 AM
Porcharu   Did you ever get the plug out?   Jan 8 2008, 01:51 PM
racunniff   Did you ever get the plug out? Yep. That last ...   Jan 8 2008, 09:04 PM
- Lo-Fi Version Time is now: 6th April 2025 - 06:30 PM
