> tranny drain plug stripped, what to do
drewvw
post Apr 3 2006, 04:52 PM
new england car guy
I went to change my tranny fluid today and found that my drain plug is rounded out pretty good. Fill plug is fine, and I was happy to find she was at least filled with oil.
Questions:
1) Whats the best way to get this thing out of there? I don't have a welder. Can I JB Weld a hex bolt in there and break it free? Looks like it hasn't moved in decades.
2) I took out that plug on the bottom (the one with the spring and ball bearing) in an attempt to get it to drain. Went back in fine...did I screw anything up by taking it out??
Thanks in advance...
drew
drewvw
post Apr 4 2006, 08:37 PM
new england car guy
QUOTE (bd1308 @ Apr 4 2006, 06:28 PM)
I think we're just splitting hairs here....
b
probably true. I need something to chat about while I watch the red sox get spanked by the rangers....
TimT, nice pull there with the chart
drewvw   tranny drain plug stripped   Apr 3 2006, 04:52 PM
lapuwali   The spring and ball bearing bit has quite a few pa...   Apr 3 2006, 05:02 PM
drewvw   when I took out the detent plug, the car was in fi...   Apr 3 2006, 05:12 PM
bondo   With the shift fork shafts in place, the other bit...   Apr 3 2006, 05:20 PM
wbergtho   I had a similar problem w/ my drain plug on my 915...   Apr 3 2006, 08:27 PM
drewvw   That was you, I read that post about the welding i...   Apr 3 2006, 08:35 PM
Dr Evil   Magnesium will not stick to the magnet, Bondo. I...   Apr 3 2006, 09:46 PM
Aaron Cox     Apr 3 2006, 09:47 PM
SLITS   I used a chisel and BFH...it came out.....I put th...   Apr 3 2006, 09:50 PM
Dr Evil   ...   Apr 3 2006, 10:14 PM
Cap'n Krusty   Why change the oil at all? It doesn't wear ou...   Apr 3 2006, 10:29 PM
Dr Evil   Don e it many times with a propane torch. Never a ...   Apr 3 2006, 10:31 PM
bd1308   so you CAN torch a mag case? cant weld it though....   Apr 3 2006, 11:04 PM
Tobra     Apr 4 2006, 12:18 AM
Porcharu     Apr 4 2006, 12:40 AM
drewvw   The tranny isn't making any horrible sounds, b...   Apr 4 2006, 09:39 AM
Cap'n Krusty     Apr 4 2006, 09:48 AM
Mueller   the cap'n is correct.....many manufactures of ...   Apr 4 2006, 10:28 AM
Tobra   As I said in my original post, regardless of facto...   Apr 4 2006, 04:22 PM
bondo   It also fills with brass and molybdenum bits which...   Apr 4 2006, 05:39 PM
SLITS   Synthetic leaks out faster........ ...   Apr 4 2006, 06:47 PM
drewvw     Apr 4 2006, 07:52 PM
bd1308     Apr 4 2006, 08:15 PM
drewvw   Noted. This is an ongoing argument I've had w...   Apr 4 2006, 08:18 PM
bd1308     Apr 4 2006, 08:21 PM
drewvw   Yeah but I've driven old european cars with lo...   Apr 4 2006, 08:25 PM
bd1308   I recall someone saying it was in the manual...and...   Apr 4 2006, 08:28 PM
TimT     Apr 4 2006, 08:33 PM
Tobra   Why on Earth would you sell an S2K? I want one, c...   Apr 4 2006, 08:55 PM
drewvw     Apr 4 2006, 09:07 PM
Tobra   Too bad, I want one of those when the integra dies...   Apr 4 2006, 09:10 PM
drewvw   it was time...I had it for 3 years and started rec...   Apr 4 2006, 09:14 PM
Porcharu     Apr 4 2006, 11:52 PM
racunniff   I ran into this problem - but it was the *fill* pl...   Jan 7 2008, 08:30 PM
Danny_Ocean   Can you drill out the plug with a slightly smaller...   Jan 7 2008, 08:50 PM
racunniff   Can you drill out the plug with a slightly smalle...   Jan 7 2008, 08:52 PM
Dr Evil   I may have a spare plug for ya. You can get a 17mm...   Jan 7 2008, 11:05 PM
Blood red 914-6gt   I may have a spare plug for ya. You can get a 17m...   Jan 7 2008, 11:08 PM
jd74914   but Snap-on is ridiculously expensive . . .   Jan 7 2008, 11:20 PM
Blood red 914-6gt   But worth every penny :D When I was wrenching a fe...   Jan 7 2008, 11:34 PM
Rusty   This thread is a blast from the past... Nice pi...   Jan 8 2008, 06:23 AM
Porcharu   Did you ever get the plug out?   Jan 8 2008, 01:51 PM
racunniff   Did you ever get the plug out? Yep. That last ...   Jan 8 2008, 09:04 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 06:26 PM
