In dire need of weber IDF part!!!, fuel enrichment circuit piece.... |
Aaron Cox |
Apr 8 2006, 07:35 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
huge thanks to brad/clayton/kevin/joer
well, brad rocks (we knew that) everyone said when you remove the choke/fuel enrichment circuit, you pull the 2 little springed psitons inside... WRONG. there are like 15 types of IDF's, and if yours came with chokes, all the choke passages are drilled..... i need this part badly! my car was a fuel pump.... must have been 1:1 AFR....... oil change here we come..... I NEED THIS PART BY SATURDAY !!! PLEASE HELP! ANYONE HAVE PARTS CARBS???? I Mostly just need the "spring clip" at the top, but will take it all if you got it. Aaron Cox acox914@comcast.net Attached thumbnail(s) |
MattR |
Apr 8 2006, 10:56 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Good thing the rings were seated......
Lo-Fi Version | Time is now: 20th June 2024 - 06:02 AM |
