dragging clutch, renegade w/kennedy PP and clutch |
Dr. Roger |
Apr 14 2006, 01:37 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
she's got a new flywheel, PP, T/O bearing, clutch plate, clutch cable, pedal cluster looks and feels good and is well lubed, rear wheel looks and feels good/lubed, bronze rear shifter bushing and good front busings.
i've driven her about 50 miles and have adjusted the clutch 4 times already. every time tightening the adjuster nuts. now it's getting hard to get into gear... (IMG:style_emoticons/default/blink.gif) this doesn't seem to be right. is this the notorious clutch tube problem??? is there a way to check for this? big thanks in advance... Roger |
rick 918-S |
Apr 14 2006, 01:27 PM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I had the same problem. Had to keep adjusting the cable. I know it wasn't from too much cable tension as I was running a stock 1.7 PP. By the time I pulled the motor and transaxle I couldn't down shift at all. I adjusted the cable so much I was sure the T.O.B was riding on the P.P. When Brad Mayeur went through My transaxle he said it looked fine. I deduced my pressure plate died. I had 5000 miles on a 6 puck clutch and it was worn to the rivets.
Lo-Fi Version | Time is now: 27th December 2024 - 09:01 PM |
