I know I'm making this harder than it needs to be!, Timing Help!!!!!!!!!!!! |
computers4kids |
Apr 15 2006, 03:58 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
OK, I've got my vaccumm advance plugged and my timing light hooked up with the inductive lead on cylinder 1. I've read the pelican article on timing and it contradicts my Clymer shop manual. Pelican says you time a 1.8 at 800-900 rpm at 7.5BTDC, while 1.7 and 2.0s you time at 3500 rpm. My manual says its 3500 rpm for all 4s??? Which is it??
Secondly, I'm having a difficult time finding TDC. With the cap off I've rotated the engine until the rotor is pointing at the TDC notch on the distributor. The marks on my housing/pulley are not to be seen. Is it suppose to be near the one flatten blade on the fan? Yes, I rotated the engine 180 degrees as well. Does this picture look like I've got the right idea for finding 7.5 BTDC? Attached image(s) |
Aaron Cox |
Apr 15 2006, 07:13 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
you really need to be looking. the marks tend to be toward the rear of the fan (ie closest to the block) vs being on the pulley part. put a blanket down and lay on your trunklid to see.
it also helps to go get an adjustable timing light. it delays the spark X degrees so the only mark you need is the TDC. go get a thing of your wifes nail polish or a paint pen, find TDC and make it visible with aforementioned marking devices. then take the timing light, set it to desired advance, and rotate dizzyy until you see the TDC mark. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:27 PM |
