> Nascar sway bar install, How I did it. Pics!
Andyrew
post Apr 21 2006, 05:43 PM
Spooling.... Please wait
Well, heres what i've been doing past couple of days, between work...
Dad told me to make it strong enough to lift the car... so hopefully I did..
My welds were not what I would have liked them to be.. there was something wrong with my welder, it was giving me inconsistant wire speed. I'll take it in and have it looked at. and the angles were hard...
I can make good welds.. Honest (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/welder.gif)
bla bla bla...
heres the pics
neo914-6
post Apr 22 2006, 03:53 PM
neo life
Are those grease fittings that will be buried under the tank? Suppose this won't be done too often...
Nice adaptation, when will the NASCAR motor go in? (IMG:style_emoticons/default/biggrin.gif)
When will you be running? Chris, Harry, and Bud are running...
Andyrew
post Apr 22 2006, 05:04 PM
QUOTE(neo914-6 @ Apr 22 2006, 02:53 PM) *
buried... lol
Well it was either greasable or non greasable.. (or roller... but that would have been $$ and alot more fabrication...) I figured, why not go greesable...I can make a hole in the firewall to put a grease gun through.. but im not worried about it. Takes 10 minutes to move a gas tank around to have room to greese it (the gas tank is actually still installed. just moved off..)
Nascar motor? next year...
Sorry.. Bar Dia is 1 1/4 on the big side and 3/4 on the small side. solid tube. I figure the metal is much stronger, its not 3/4 all the way through, and its shorter (37.5in, firewall is 32in or so) so it should be stiffer than a 19mm sway bar, probably more like 21 or bigger..
So far it cost
75 for the bar and arms
15 for the metal
15 for the bushings
20 for the wire and gas to weld it.. (rounded way up... lol)
and probably about 50 in more metal and rod ends. (coleman)
Better than a $500 sway bar...
Andrew
Oh ya.. I'll be up and running... never.. Mike P's trani seems like its locked between gears, so I think it HAS to be rebuilt.. so if I want this thing running quickly I'll have to make this a 2 step process..
If I just wanted it running... it would be about another month.. to throw everything in, and finish the sway bar. (and to get money for the tires... lol)
If I wanted it painted, interior done, my bracing done, front hood done, radiator shrouding done, 944 turbo front bumper done, and 915 lsd trani in... probably 3-6 months. ie end of summer.
FYI felix, Im planning on an American Graffiti party at my house...
Andyrew   Nascar sway bar install   Apr 21 2006, 05:43 PM
Andyrew   missed one..   Apr 21 2006, 05:46 PM
Brando   1.5" swaybar? That is cool! Any gas-tank...   Apr 21 2006, 07:33 PM
trekkor   I like where this is heading. :clap: On the welde...   Apr 21 2006, 10:07 PM
Aaron Cox   yummy! "Goober welds" :chow: neat m...   Apr 21 2006, 10:11 PM
Andyrew   The hardest part so far was getting it correct in ...   Apr 22 2006, 04:39 AM
marks914   Nice, I am currently considering the same thing,...   Apr 22 2006, 06:09 AM
Thorshammer   This is a difficult job, and your solution is rath...   Apr 22 2006, 12:12 PM
Andyrew   Eric... I know how to weld... but its configuring ...   Apr 22 2006, 02:25 PM
neo914-6   Are those grease fittings that will be buried unde...   Apr 22 2006, 03:53 PM
Andyrew
- Lo-Fi Version Time is now: 11th April 2025 - 01:44 AM
