sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
I looped it at the end of the slalom. I was already on the go pedal hard when she lost traction. I did not expect it, didnt even feel it start to come loose till...whoops(wrong line? marbles? dirty?) well, I did not push the clutch in fast enough and rotated teh engine and trans backwards. the abrupt change in direction of all that mass rotating at 4000rpm was a rather violent affair. I did not photo document everythign because this mornign my camera battery was dead and I just wanted to get it done.
the flywheel and crankshaft were tight. they were in fact welded together from the intense heat geneerated. the locate pin was sheered off. teh bolt holes in teh flywheel are ovaled out. the bolts were bent and left thread marks inside teh bolt holes. the cooling fan sheered off all 3 bolts and the drift pin. the fan and flywheel are now toast Attached image(s) ![]() ![]() |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Wow, I never thought such a small amount of rotation would cause that much galling! It couldn't have moved more than a few degrees, right? It seems to me that a flywheel would never sit flat on that crank now, and it could lead to wierd clutch problems.
Lo-Fi Version | Time is now: 26th June 2024 - 07:20 AM |
