Weber IDF's, How do I plug this hole? |
ematulac |
Apr 27 2006, 12:02 AM
914 addict Group: Members Posts: 540 Joined: 24-November 03 From: Palmdale, CA Member No.: 1,382 |
Looks like that lead plug was in the hole. The plug popped out and my fuel bowl was emptying out into the engine compartment.
Is there a better way to plug that hole? |
Joe Ricard |
Apr 27 2006, 05:31 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
JB weld. Seriously. New plug is most likely one of those unabotanium pieces.
The plug is pressed in at the factory I doubt you can replicate it. It will leak agan anyway. The hole is a result of the boring process for one of the fuel circuits. Main gas I think. JB weld is gas resistant. Don't get it inside the hole as it WILL plug the passage and you will then be screwed. |
ematulac |
Apr 27 2006, 07:10 AM
JB weld. Seriously. New plug is most likely one of those unabotanium pieces. The plug is pressed in at the factory I doubt you can replicate it. It will leak agan anyway. The hole is a result of the boring process for one of the fuel circuits. Main gas I think. JB weld is gas resistant. Don't get it inside the hole as it WILL plug the passage and you will then be screwed. JB Weld sounds doable, and I don't even need to run to the store for it. So I should replace the plug and JB weld it to the outside of the carb? Here's a close-up of the hole. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:45 AM |
