pete-greggers |
Newbie ![]() Group: Members Posts: 23 Joined: 4-December 04 From: vancouver bc Member No.: 3,220 Region Association: None ![]() |
i am re-installing a 2.0 four from a late 75 car and want to install my 40 idf webers on the new motor, which has fuel injection....i am also installing an external oil cooler...mounted in the engine bay.....any tips i should consider...such as the cam, will i need to change it?? the old motor has mech advance, new motor has vacuum advance...which is better?
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,106 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
you"ll need a different fuel pump. do you have a complete carb setup ready to go? why are you putting on a cooler? we really don't need them here. esp on a stockish engine. steve's car ran well going to whistler. run it as is. you can put the carbs on with the engine in if you still want to later. not that big of a deal.
k |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:39 PM |
