Fuel Injector pattern or lack there of, it wants to start really it does |
tdgray |
May 7 2006, 02:40 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Ok so here it is.
Replaced the fuel pump with an MSD (sorry Jake). Fuel pressure regulator is almost set as high as it will go. Tried multiple settings no change. Visually looked at the spray pattern of the fuel injectors. Basically a straight squirt. definitely not a mist which is what I expected. Is this right? The engine sounds as if it wants to start when I crank it. If I squirt some fuel down the throttle body it fires right up (and races like hell of course). So it's not a timing etc problem Are the injectors bad? Am I not getting enough pressure from the MSD pump? I tried to build a homemade pressure regulator but it does not seem to work very well. Can an injector go bad but still spit some fuel? What is the pattern supposed to look like? Should I just bite the bullit and get four new injectors just to be safe? HELP TOTALLY CONFUSED |
tdgray |
May 7 2006, 05:40 PM
Thanks Doc...
Got a in-line fuel pressure gauge on order from Jegs as we speak. I am getting the thought that the MSD fuelpump is not cutting it. Will verify when the gauge gets here. Just for confirmation... I should install the guage between the regualtor and the fuel rail correct???? Thanks guys..as usual |
Lo-Fi Version | Time is now: 26th September 2024 - 11:50 AM |
