seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
This is what I have for the front. My car did not have bars installed before. I have a UTab kit as well as what you see here.
What do the 4 small tabs do? Attached image(s) ![]() |
Bruce Allert |
Hellions asleep ![]() ![]() ![]() ![]() Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest ![]() |
I made mine. Just found some steel the same thickness as the outside mounts & cut them with a jig saw then drilled the holes. The lower hole was the tricky one tho. Had to use AB epoxy to hold the nut to the plate while I screwed the bolt in from the fender well... and it worked (IMG:style_emoticons/default/beer.gif)
bruce |
Lo-Fi Version | Time is now: 3rd July 2024 - 03:38 AM |
