Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Here ya go.....check out this link to see my newest daily driver engine...... Runs cooler than stock and made 210BHP with full exhaust and through the fan belt. Removed the belt for 239BHP, and all before 6K RPM.
Its the "Intimidator" and would match well to 914 gearing, already did the match..... Once again, daily driver on pump gas @ 10.3:1 http://www.shoptalkforums.com/viewtopic.php?t=56342 any questions????LOL |
reverie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 14-March 03 Member No.: 427 Region Association: None ![]() |
I've read in a Gene Berg catalog that if you multiply the compression ratio by 13, that will give you the octane of the gasoline needed for the engine. For example, if you have a compression ratio of 7.0:1, you'll need to use 91 octane gasoline.
Their catalog says that if you run a high compression ratio on today's pump gas, the engine will overheat.. valves, studs, etc. So how does a high-comp (10.3:1) engine run cooler than stock? Thanks in advance.. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 10:30 PM |
