Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,396 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Here ya go.....check out this link to see my newest daily driver engine...... Runs cooler than stock and made 210BHP with full exhaust and through the fan belt. Removed the belt for 239BHP, and all before 6K RPM.
Its the "Intimidator" and would match well to 914 gearing, already did the match..... Once again, daily driver on pump gas @ 10.3:1 http://www.shoptalkforums.com/viewtopic.php?t=56342 any questions????LOL |
Jake Raby |
Bergs chart is ridiculous. It does not take into account cam specs or dynamic compression ratio. Bergs calculations are only good if the engine NEVER RUNS!
This engine with 10.3:1 WILL NOT detonate (My dyno is equipped with a safeguard individual cylinder knock sensing systemand the light never came on) The combination is everything. Low CR is the WORST thing you can do to an engine. FYI, theleast CR I have ran all year was 8.5:1 and that was a VW Bus engine. ITS ALL IN THE COMBO!! Britain, thats the shroud you sent me. I chose to use it because in my testing the oil cooler blister HELPED ITH COOLING THE HEADS and got rid of alot of the air that we found IS NOT NEEDED. This is the last engine that will leave my shop with a 911 Shroud till mine is done in atleast a year. I have learned to really dislike them! |
Lo-Fi Version | Time is now: 1st July 2024 - 01:47 AM |
