> Ideas please......, '74 2.0 running/starting issue
theman352001
post May 25 2006, 07:59 PM
Hey guys & gals, sorry for the length, would like to be thorough.
Past Status: '74 2.0 was running great 2 years ago. Took it to a gas station to fill up a gas can (no gas was put into the car's tank) and as I was leaving the car died. I tried to start it a couple of times and was able to get it to run but as soon as I would try to give it some gas (not in gear) the car would die. The only thing I noticed differently was that the fuel pump didn't sound right.
Back then I tested the fuel pump for flow and pressure (without car running) and both seemed good. The car would start periodically and idle fine but I could not touch the accelerator without it dying. The pump still didn't sound right however.
Current status: Pulled the '74 pump and rigged up a '75 pump that tested good for flow. '74 pump seems a bit weak on flow. Car will not start at all. I am not even getting any firing.
Plugs are working fine with nice fat sparks. Also, the 2 driver's side injectors are firing a good spray of fuel. (I did not check the passenger side - assuming they are fine)
Next on my list of things to check:
  • Make sure timing hasn't somehow jumped position
  • double check Crane HI-6 ignition system
  • temperature sensor
I am interested in any other thoughts or past experiences from the group. What else should I be checking? Have you had a similar problem and what was the solution?
Thanks in advance.
D1A3
post May 25 2006, 08:20 PM
Gruppe Neun Vierzehn Südosten
Have you checked all of your electrical connections?
I seem to remember a time I had a similar sounding problem and there was a wire (don't remember for what) that is down near the base of the distributor (wide plug, red wire?) that was not firmly attached. Had me scratching my head for a good week... Once I reinserted it, everythign was fine.
I'd check that everything is plugged in, even if it looks like it is, it may not be making the proper contact.
- Lo-Fi Version Time is now: 15th January 2025 - 07:48 AM
