d-jet issues |
d-jet issues |
bd1308 |
May 29 2006, 05:46 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
So I get this new engine and put it in, runs great! Thanks Garold, you're a lifesaver.
I dirve it for a while, and notice that cold idle is REAL low. Warm it idles just a tad low, but at idle it runs RICH.... lowered performance until 1500(small amount of bog), then peaks at power at 3500 I drive at around 3500 usually (keeps it cool) Idle it runs rich, so I adjust the knob on the ECU, and I dont want it to run lean at idle. So back to the notch it goes, where its rich. I have 3 Mps's in all, including the Type III one which doesnt have a diapragm as noted in another buried thread....So in all, I have four MPS's. The one currently in the car is the "NOS" one that I paid too much for from a member here. Whatever. It didnt leak down a year ago, so I assume its still good, being that I just now used it. In four days im getting into rust repair, upon which the engine will be dropped...mayeb then I could do a valve adjustment and take care of some things. It's has some clicks at idle, maybe from the valves? For the rich thing, maybe the trigger points went bad? I'll try some from the VW guy tomorrow, he has a box with a new one in it, or i could pull one from a rebuilt dizzy I have from cardone. Any comments (less the "sell the 914" ones) add them below Car runs though! b |
Mueller |
May 29 2006, 06:32 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
there is no possible way for the trigger points to cause a rich condition...well maybe if they bounced like hell, but I couldn't see that happening unless you ran the motor to 20K rpms or higher (IMG:style_emoticons/default/smile.gif)
are the points new?? |
Lo-Fi Version | Time is now: 28th September 2024 - 03:11 PM |
