bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
So I get this new engine and put it in, runs great! Thanks Garold, you're a lifesaver.
I dirve it for a while, and notice that cold idle is REAL low. Warm it idles just a tad low, but at idle it runs RICH.... lowered performance until 1500(small amount of bog), then peaks at power at 3500 I drive at around 3500 usually (keeps it cool) Idle it runs rich, so I adjust the knob on the ECU, and I dont want it to run lean at idle. So back to the notch it goes, where its rich. I have 3 Mps's in all, including the Type III one which doesnt have a diapragm as noted in another buried thread....So in all, I have four MPS's. The one currently in the car is the "NOS" one that I paid too much for from a member here. Whatever. It didnt leak down a year ago, so I assume its still good, being that I just now used it. In four days im getting into rust repair, upon which the engine will be dropped...mayeb then I could do a valve adjustment and take care of some things. It's has some clicks at idle, maybe from the valves? For the rich thing, maybe the trigger points went bad? I'll try some from the VW guy tomorrow, he has a box with a new one in it, or i could pull one from a rebuilt dizzy I have from cardone. Any comments (less the "sell the 914" ones) add them below Car runs though! b |
ptravnic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None ![]() ![]() |
Britt,
MPS's are not created equal. Part numbers need to be matched to the correct system. From Paul Anders's writeup and specs on the Bosch D-Jet: Porsche/VW # Bosch # Engine Year 039 906 051 0 280 100 043 2.0L 1974 - 1976 022 906 051 C 0 280 100 037 2.0L 1973 022 906 051 E 0 280 100 049 1.7L 1970 - 1973 I honestly don't know what the "C' or "E" means on the Porsche/VW # but the Bosch #'s should also be stamped on the MPS. Your "NOS" might not be the right one for your setup or maybe the one which was originally on your car had been adjusted... FWIW, I tested a mismatched MPS on my car this past weekend and it would barely start. I'm trying to find a local mechanic who can correctly tune my MPS - not an easy task b/c it requires shop quality equipment (CO meter, etc). -pt |
Lo-Fi Version | Time is now: 28th June 2024 - 03:30 PM |
