> Need HELP!, Car took a dump..... pretty much
ninefourteener
post May 26 2006, 05:08 PM
Perfectly Normal Guy :)
Greetings..
Is there ANYONE in the St. Louis area that can help me out? I don't mind paying, but I don't trust any local reapir shops.... unless someone can suggest someone.
My carbs are so far out of whack...... I can't figure it out.
Car runs "ok" when you first start it up cold, but once it gets warm, it has literally almost no power at all...... to the point where I have to "pump" the gas a few times, just to get the RPMs up...... then turn it to 4K...... then SLOWLY let out the clutch, just to get enough torque to get it moving.
Then at the next stoplight..... it dies..... unless I keep my foot on the gas.
I looked up how to properly tune Solex carbs..... followed the directions...... and I think I just ended up making it worse.
Now I'm afraid to drive it, as it LITERALLY won't get out of it's own way.
I need a carb tuning expert.... near O'Fallon, Belleville, Shiloh, or Fairview Heights, Illinois.
Anyone?? Suggestions on repair shops?? Anyone nearby wanna come tune this thing correctly for me??? Help.....
--Matt
ninefourteener
post May 30 2006, 08:26 AM
Folks....... another quick question....... I just had an interesting thought.
Would old gas prohibit the car from running correctly, and prohibit me from getting a good tune on the carbs?
I mean, I filled it up with new gas, but it had 1/2 tank in it when I did....... the 1/2 tank was probably close to 6 months old... I really haven't driven it since Sept. of last year.
I expected it to run a little "rough" at first....... but I can't even keep it running.
Could that be it?
Another question: If I disconnect the fuel line under the car, right by the passenger long (where the fuel filter is).... will all the gas drain out? Or should I try somewhere else?
- Lo-Fi Version Time is now: 6th January 2025 - 03:49 PM
