Ideas please......, '74 2.0 running/starting issue |
theman352001 |
May 25 2006, 07:59 PM
Newbie Group: Members Posts: 16 Joined: 21-March 06 From: Wisconsin Member No.: 5,750 |
Hey guys & gals, sorry for the length, would like to be thorough.
Past Status: '74 2.0 was running great 2 years ago. Took it to a gas station to fill up a gas can (no gas was put into the car's tank) and as I was leaving the car died. I tried to start it a couple of times and was able to get it to run but as soon as I would try to give it some gas (not in gear) the car would die. The only thing I noticed differently was that the fuel pump didn't sound right. Back then I tested the fuel pump for flow and pressure (without car running) and both seemed good. The car would start periodically and idle fine but I could not touch the accelerator without it dying. The pump still didn't sound right however. Current status: Pulled the '74 pump and rigged up a '75 pump that tested good for flow. '74 pump seems a bit weak on flow. Car will not start at all. I am not even getting any firing. Plugs are working fine with nice fat sparks. Also, the 2 driver's side injectors are firing a good spray of fuel. (I did not check the passenger side - assuming they are fine) Next on my list of things to check:
Thanks in advance. |
drewvw |
May 30 2006, 09:18 AM
new england car guy Group: Members Posts: 1,631 Joined: 24-February 06 From: Boston, MA Member No.: 5,630 Region Association: North East States |
seems like checking the CHT should be next on the list. I believe one of the textbook symptoms is that a bad CHT can make the car run so rich it won't stay running. maybe the wire is shorting or something like that too.... |
Lo-Fi Version | Time is now: 15th January 2025 - 08:08 AM |
