DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
Got everything back together...
Screw in BBS 80mm studs. 1/2 inch spacers in rear and 3/4 inch spacers in front (thanks Mike Mueller), Good thing I did this. these old cars are just not very square.... right rear was rubbing on the inside fender well...pretty much the entire semicircle. left rear was rubbing in just a small spot. Due to my pretty aggressive negative camber. -2.75 in the rear. car is bound to be faster since I dont have a built in rubber brake system now (IMG:style_emoticons/default/smile.gif) I have had 2 other 4 cylinder 914s with very similar setups with no rubbing issues. Stance looks much better now. (IMG:style_emoticons/default/biggrin.gif) |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Where and what did you get for BBS studs Dan?
Lo-Fi Version | Time is now: 29th June 2024 - 03:07 AM |
