How many bolts hold on the plenium? |
tod914 |
Jun 2 2006, 11:56 AM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
75 2.0... only seen one towards the front.. I assume there are more??
Thanks |
So.Cal.914 |
Jun 2 2006, 05:11 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Gadd's, Dave the human 914 encyclopedia.
jd66921 |
Jun 2 2006, 06:02 PM
Member Group: Members Posts: 316 Joined: 9-January 06 From: Texas Member No.: 5,394 |
Okay Dave (or whoever), is it easy enough to remove the whole plenum since it is
almost impossible to install the throttle body to the plenum? This is a 1.8 L-Jet. How many bolts are there? Thanks, Jeff |
jd74914 |
Jun 2 2006, 08:39 PM
Its alive Group: Members Posts: 4,819 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Okay Dave (or whoever), is it easy enough to remove the whole plenum since it is almost impossible to install the throttle body to the plenum? This is a 1.8 L-Jet. How many bolts are there? Thanks, Jeff I actuallu put mine on and took it off again 3 times 2 weekends ago. Its very easy and IIRC there are 3 bolts to the case from the plenium. I found that it was much easier to pull off the plenium to put the TB and a few other things on, than leaving it on. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th January 2025 - 07:55 PM |
