> Body Solder vs. Plastic (Bondo) Filler, what's better
dkos
post Jun 6 2006, 09:48 AM
say, "RUST"!
Making my first attempts at body work, welded in the patch piece and grinded it down. Now what do I do to make it smooth? Plastic body filler like Bondo? I'm a little wary of using lead. I'm working in my garage and I have kids around. Don't want to poison anyone. Eastwood has a lead-free solder kit, but it's not cheap ($150). Is it any good? Is it worth the extra cost? Should I treat the bare metal patch area with something before I use body filler/solder?
Thanks for your help
Cornholio
post Jun 6 2006, 10:05 AM
Unregistered
Both are an exercise in patience and experience. IF done right both will serve the purpose..read the instuctions, good prep PROPER mixing of the bondo at the right temperatures will give a filler.
Flex is a killer....
Lead....if a proper mask is worn is not a bad filler.
The lead free solder...not tried it.
dkos   Body Solder vs. Plastic (Bondo) Filler   Jun 6 2006, 09:48 AM
Cornholio   Both are an exercise in patience and experience. ...   Jun 6 2006, 10:05 AM
Aaron Cox   if you want metal... look at "all metal...   Jun 6 2006, 10:08 AM
dkos   Aaron, I googled "all metal" and nothi...   Jun 6 2006, 11:42 AM
Aaron Cox
- Lo-Fi Version Time is now: 22nd December 2024 - 09:59 AM
