/6 valve cover leak......still |
Dr Evil |
Jun 7 2006, 09:24 AM
Send me your transmission! Group: Members Posts: 23,032 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So I got the new silicon covered valve cover gaskets and put them on last time I ran the car hoping that this would solve the oil incontenance my engine is suffereing.....nope. Then I recalled that I may have been expecting a bit too much from these new fangled gaskets. My old valve cover has some corrosion on the mating surface that is potentially the cause, or at least an exacerbating factor of this leak. That plus the tooling marks on the head probably did it in. Thus, I just scored a good deal on some turbo valve covers (they realy have come down in price for new, though) and hope to have them in by Fri.
Some thoughts about hte other part of this problem, the mating surface of the cam towers. Q: Could I fill in any tooling marks with a filler of some sort and sand smooth? ex; quick steel, jb weld, etc. So long as this compound is not heat sensitive and can withstand oil I think it would work. Comments? |
Dr Evil |
Jun 7 2006, 12:31 PM
I didnt have to drop the engine the other SEVERAL (due to oil leak) times that I have had to remove the valve covers recently. Oddly enough, I did have to remove the oil line on the one side and then bend the outlet out a little. I think my engine mount puts my engine a little forward and my oil cooler adaptor mod put the damn fitting about an inch closer than it could have been. I'll just measure the original covers for clearance and match the specs to the new ones.
Thanks for the info and idea about the bolts, but no way do I want to start helicoiling and such.....I hope I do not have to change my tune about that later. Hey, for the JB Weld should I only use the long time to dry stuff (original) or would the JB quick work as well (I have some already)? |
Lo-Fi Version | Time is now: 27th September 2024 - 11:31 AM |
