tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
Seems once a year I'm fixing a small leak around the guide bush where it goes into the tranny. Each time I replaced the o-ring and used hylomar. After time,
it leaks again. Any reckomendations on a better sealant??? The angle drive is new too, so thats ok. Thanks |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
My money's on a worn bore in the nose cover. If that's the case (and it's REALLY common) there's little you can do. Since there's RARELY any reason to remove the speedo drive insert, a more permanent repair might be your best move. In the past I've found JB Weld performs well in this specific repair. The Cap'n
Lo-Fi Version | Time is now: 26th June 2024 - 07:11 AM |
