mikelsr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region ![]() |
When I turn on my right turn signal the fuse blows (left works fine). This happened the second time I drove it this year.
Here is what I am doing, if anyone has any suggestions I would like to hear them. 1) disconnected the wiring from the front and rear indicators, 2) removed the flasher relay, 3) removed the right side signal wiring from the emergency flasher and it still indicates a short in the wiring (or course there is still a bulb in line). To do tomorrow: 4) remove the wiring from the turn signal indicator (or remove the bulb) in the dash (needed to fix the speedo anyway). 5) That should leave me with only the turn signal switch. I removed the steering wheel (always nice to have the proper size socket ahead of time -- I asked my family to get me one for xmas last year and they did). Is there a secret to removing the turn signal switch from the steering column? I haven't attemtped it yet but will tomorrow. With everything disconnected I should only have wiring to look at. If the wiring shows no shorts, then it is either the turn signal indicator or the turn signal switch. I would suspect the switch. If there is a short then I have to divide the wiring up between the front and the back. Is there any connectors that can be disconnected that will separate the turn signal wiring front to back? Thanks for any help you can give me. Mike |
Lo-Fi Version | Time is now: 26th June 2024 - 03:00 AM |
