rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
I installed a brand new battery and a new voltage regulater last week in the car. My volt meter is showing 12.5 volts at the terminals. With the car running and the lights and fan on my volt meter fluctuates between 12.7 and 12.9, then slowly starts to dip, getting as low as 12.5 before I decided to shut the engine off because I could see that the battery was slowly draining.
Would it be logical that the alternator might need replacing? The alt. belt also seemed tight (not sure exactly how tight it should feel though.) I can check the electrical connections (have to find them first though.) The connections at the battery all look good though. It doesn't look like a fun job to replace the alternator, but I'm up for the challenge. Anything else I should look for before I go this route?? Thanks! PS: Forgot to add that the alternator light on the dash comes on when starting the car, but goes off right away once it's started and doesn't come back on at all when driving. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Check the ground circuit: measure the voltage difference between the negative post on the battery and the fan shroud. The alternator grounds through its case to the fan shroud, then the engine, transmission, up the ground strap and through the body to the battery strap and then the post. That is a long path with lots of connections. If you get much of a voltage difference, then start checking the ground straps. If you are relying on the console voltmeter, then forget it, since it never reads correctly. A DVM is the only tool to do this sort of a test.
nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
had a similar problem. are you sure the regulater is good?. if there is any doubt check my post "atlernator problems is anything simple?" on page 6 of the garage forum. there is a test you can do to test the regulator. good luck
Lo-Fi Version | Time is now: 26th June 2024 - 02:09 AM |
