BigDBass |
Dumb Question Champion ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest ![]() |
Working on front brakes/rotors/bearings, etc. Calipers were supposed to be here but didn't show up. I had help putting in bearing races and some orientation and all that. Mounted the rotors, put in outer bearing and washer, installed retaining nut thing finger tight, tightened the allen, and greased it a bit. Then got stuck trying to "tap on grease cap with soft faced hammer" trying a rubber mallet then a regular household hammer with a rag wrapped around it but it was basically going on flush only on one side . Called auggie91420 and he said just bang the crap out of it. So I did so and the grease cap is no longer domed or shapely at all. How bad is that? Do I now need to track another one down? Sorta got it on all the way, but then the rotor wouldn't spin freely. It would bind in one spot, so I backed off the cap a bit. It doesn't make much sense to me that the cap could interfere with the rotor spinning? Should the cap (rubber seal part) be flush with the rotor or should there still be a gap? I still have a gap there, and if I put the cap on any tighter/deeper the rotor binds. (IMG:style_emoticons/default/WTF.gif) |
BigDBass |
This is the one I banged up last night
![]() Passenger on as good as it'll go without mangling with hard hammer: ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 07:33 PM |
