Electrical charging system question, Alternator? |
rjames |
Jun 10 2006, 04:11 PM
I'm made of metal Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I installed a brand new battery and a new voltage regulater last week in the car. My volt meter is showing 12.5 volts at the terminals. With the car running and the lights and fan on my volt meter fluctuates between 12.7 and 12.9, then slowly starts to dip, getting as low as 12.5 before I decided to shut the engine off because I could see that the battery was slowly draining.
Would it be logical that the alternator might need replacing? The alt. belt also seemed tight (not sure exactly how tight it should feel though.) I can check the electrical connections (have to find them first though.) The connections at the battery all look good though. It doesn't look like a fun job to replace the alternator, but I'm up for the challenge. Anything else I should look for before I go this route?? Thanks! PS: Forgot to add that the alternator light on the dash comes on when starting the car, but goes off right away once it's started and doesn't come back on at all when driving. |
rjames |
Jun 12 2006, 03:30 PM
All good info, will be testing tonight. The thing that got me checking on things in the first place is that I just bought a new battery, put it in and was amazed at how bright the turn signals were. I could actually seem them from inside the car. Measured the voltage which was close to 13 with the engine off. Drove around for a day or two, then the turn signal indicator inside stopped working after a couple of blinks, and the turn signals weren't as bright, and with the headlights on the RPMs dropped by 200. Seems like classic alternator problem, but then again with these cars very little is often obvious to me.
Lo-Fi Version | Time is now: 26th June 2024 - 02:20 AM |
