> Rear Alignment, ... anybody have a tech article?
vesnyder
post Jun 15 2006, 07:04 AM
I just redid the entire rear end on my 914 - had to replace one of the rear control arm mounts so I replaced all the bushings - and now I am putting it all back together. Anybody have details on how may shims I shoudl start with and what I need to do to make sure it at least close on alignment? Fow some reason there were three shims on one side and none on the other? Just curious where the adjustments are made and how I can make sure it is close just to road test.
TravisNeff
post Jun 15 2006, 12:19 PM
Since you replaced the console (which would be the reason for the extra shims - I am assuming the shimmed side was the passenger side) I would start with no shims at first and just eyeball if each side looks even once you get it back on the ground. If you need less negative camber, add a shim and look again. You won't know for sure until you get it to an alignment shop anyhow.
vesnyder   Rear Alignment   Jun 15 2006, 07:04 AM
East coaster   Just did mine too......... :popcorn:   Jun 15 2006, 07:21 AM
brant   probably put back what was in there and make certa...   Jun 15 2006, 09:04 AM
Travis Neff   Since you replaced the console (which would be the...   Jun 15 2006, 12:19 PM
Joe Ricard   Well I have over 1/2 inch of shims in my car. Very...   Jun 15 2006, 01:37 PM
vesnyder   Come on guys, racers do it with string - I should ...   Jun 15 2006, 08:15 PM
brant
- Lo-Fi Version Time is now: 29th April 2025 - 08:53 PM
