> My SDS EFI install, What, me working on my own stuff? no way
Mark Henry
post Oct 1 2003, 11:26 AM
that's what I do!
My programmer, mixture knob and air/fuel meter.
JeffBowlsby
post Oct 1 2003, 01:13 PM
914 Wiring Harnesses
Mark that looks really fine so far.
The multi-pin connector maybe / maybe not a good idea...
Good: It could be mounted to the firewall in sealant for a watertight connection
Bad: It introduces a full set of connections...which are susceptible to corrosion and vibration. If its a watertight cap then that takes some of the risk out of it.
Given any thought to just mounting the ECU inside the OEM brainbox for a sleeper look?
I like the SDS alot because it is programmable by a dedicated module that stays with the car. With laptop systems, who knows if your laptop will be supported in about X years...when you need it most.
Anxious to see your further results.
Mark Henry   My SDS EFI install   Oct 1 2003, 11:26 AM
Mark Henry   It's mounted to an old ashtray. I will remove ...   Oct 1 2003, 11:31 AM
Mark Henry   ashtray   Oct 1 2003, 11:32 AM
Mark Henry   TPS mount   Oct 1 2003, 11:33 AM
Mark Henry   TPS on the TB   Oct 1 2003, 11:35 AM
Mark Henry   More pic's to come soon! I have to punch ...   Oct 1 2003, 11:49 AM
Mueller   It's about time you worked on your damn car ...   Oct 1 2003, 12:21 PM
Mark Henry   Where do you get that? Cost? I was just going to ...   Oct 1 2003, 12:43 PM
Jeff Bowlsby   Mark that looks really fine so far. The multi-pin...   Oct 1 2003, 01:13 PM
Mark Henry     Oct 1 2003, 02:17 PM
Aaron Cox   i used to know a place where you could get MIL-SPE...   Oct 1 2003, 03:47 PM
Mark Henry   My crank trigger disk, the magnets 180 apart are t...   Oct 2 2003, 07:59 PM
Mark Henry   on the engine   Oct 2 2003, 08:05 PM
Mark Henry   the sensor mounted   Oct 2 2003, 08:08 PM
Mark Henry   All together now!   Oct 2 2003, 08:11 PM
Mark Henry   The backside   Oct 2 2003, 08:12 PM
Mark Henry   Had to plug the dizzy hole. Cut this off of an old...   Oct 2 2003, 08:14 PM
Mark Henry   I've done it now! Me old 1.8 L-jet. Bye-...   Oct 2 2003, 08:17 PM
Mark Henry   My new JYD 2.0 SDS PEFI engine!   Oct 2 2003, 08:19 PM
Mark Henry   SDS ECU and coil.   Oct 2 2003, 08:24 PM
Mark Henry   How they plug in.   Oct 2 2003, 08:25 PM
Mark Henry   sorry I forgot the pic: the SDS ECU and coil.   Oct 2 2003, 08:30 PM
Mark Henry   The main harness, bit low tech but it is well made...   Oct 2 2003, 08:35 PM
Jeff Bowlsby   Mark, that harness doesnt look so bad, it looks li...   Oct 7 2003, 03:04 PM
Mark Henry   Hi all! :wavey: I doubt if I will get it don...   Oct 28 2003, 11:49 AM
redshift
- Lo-Fi Version Time is now: 22nd November 2024 - 06:15 PM
