> My SDS EFI install, What, me working on my own stuff? no way
Mark Henry
post Oct 1 2003, 11:26 AM
that's what I do!
My programmer, mixture knob and air/fuel meter.
Mark Henry
post Oct 1 2003, 02:17 PM
that's what I do!
QUOTE(bowlsby @ Oct 1 2003, 11:13 AM)
Given any thought to just mounting the ECU inside the OEM brainbox for a sleeper look?
I like the SDS alot because it is programmable by a dedicated module that stays with the car.  With laptop systems, who knows if your laptop will be supported in about X years...when you need it most.
Anxious to see your further results.
I thought about mounting it in an old box, but it would be a pain connecting/disconnecting the controller. Once you are done programing you lock it off and remover the controller.
Unless you want to run the progammer cable outside the car (not long enough but it is just an old style mouse cable) you have to still drill a hole. I'm going to see if I can get a PS2 cable adaptor, if I can (and it works) then I'll mount it your way and drill a smaller hole. SDS is warns that the ECU is not waterproof and they would rather you mounted it inside the cab.
Also the harness is far from stock looking, if I really wanted it to look like stock I would give it to you for the once over.
I have more pic's being developed as we speak, so more to come soon.
(IMG:style_emoticons/default/MDB2.gif)
Mark Henry   My SDS EFI install   Oct 1 2003, 11:26 AM
Mark Henry   It's mounted to an old ashtray. I will remove ...   Oct 1 2003, 11:31 AM
Mark Henry   ashtray   Oct 1 2003, 11:32 AM
Mark Henry   TPS mount   Oct 1 2003, 11:33 AM
Mark Henry   TPS on the TB   Oct 1 2003, 11:35 AM
Mark Henry   More pic's to come soon! I have to punch ...   Oct 1 2003, 11:49 AM
Mueller   It's about time you worked on your damn car ...   Oct 1 2003, 12:21 PM
Mark Henry   Where do you get that? Cost? I was just going to ...   Oct 1 2003, 12:43 PM
Jeff Bowlsby   Mark that looks really fine so far. The multi-pin...   Oct 1 2003, 01:13 PM
Mark Henry     Oct 1 2003, 02:17 PM
Aaron Cox   i used to know a place where you could get MIL-SPE...   Oct 1 2003, 03:47 PM
Mark Henry   My crank trigger disk, the magnets 180 apart are t...   Oct 2 2003, 07:59 PM
Mark Henry   on the engine   Oct 2 2003, 08:05 PM
Mark Henry   the sensor mounted   Oct 2 2003, 08:08 PM
Mark Henry   All together now!   Oct 2 2003, 08:11 PM
Mark Henry   The backside   Oct 2 2003, 08:12 PM
Mark Henry   Had to plug the dizzy hole. Cut this off of an old...   Oct 2 2003, 08:14 PM
Mark Henry   I've done it now! Me old 1.8 L-jet. Bye-...   Oct 2 2003, 08:17 PM
Mark Henry   My new JYD 2.0 SDS PEFI engine!   Oct 2 2003, 08:19 PM
Mark Henry   SDS ECU and coil.   Oct 2 2003, 08:24 PM
Mark Henry   How they plug in.   Oct 2 2003, 08:25 PM
Mark Henry   sorry I forgot the pic: the SDS ECU and coil.   Oct 2 2003, 08:30 PM
Mark Henry   The main harness, bit low tech but it is well made...   Oct 2 2003, 08:35 PM
Jeff Bowlsby   Mark, that harness doesnt look so bad, it looks li...   Oct 7 2003, 03:04 PM
Mark Henry   Hi all! :wavey: I doubt if I will get it don...   Oct 28 2003, 11:49 AM
redshift
- Lo-Fi Version Time is now: 22nd November 2024 - 06:03 PM
