vincesix |
Newbie ![]() Group: Members Posts: 38 Joined: 20-December 04 From: Riverside,CA Member No.: 3,313 ![]() |
with all new syncros, mainshaft bearing, 5th gear and everything else checked as good including the shift rod and bushings. doubled checked the fork and all settings and the SOB will not stay in 2 nd under power. WTF.
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
You have the shift fork out of alignment. It is not engaging second all the way. I bet it goes into third with ease?
You only have 4 options with what could be wrong. 1.worn slider 2.worn dog teeth 3.worn brake band 4.out of alignment fork I have had guy's in the past who beat the shit out of second gear at AutoX and would move their 2nd gear shift fork to the point that it wouldnt engage the gear. 3rd worked great (it gets closer to 3rd when it moves) We cure this issues in G50's by pinning the fork to the shaft (same with 901/915's) Can you pull the shift console down and shoot a pick of the shift rods in neutral for me? B |
Lo-Fi Version | Time is now: 26th June 2024 - 03:56 AM |
