Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
was wondering because the early /4 use the same pads as a /6. the later /4's have their own pads.
/6 pads are bigger right? |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
... And you have to drill one of the pad holes bigger to fit the pin.
Maybe I missed your real question: The /6 front calipers are different from the /4, the pads may be the same size, but the pistons are a lot bigger (in the same ratio of 19mm/17mm master cylinder, BTW). The later /4 pads were thicker, not bigger. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:35 AM |
