monkei |
slave to rust.... ![]() ![]() Group: Members Posts: 137 Joined: 10-August 04 From: Pleasanton, CA Member No.: 2,504 ![]() |
so i have a wiring harness with crumbled connections and broken wires. last time i tried to start my 74 2.0 914 after gutting the interior i hooked up the battery only to discover magic smoke coming from near my aternator out of the fan shroud.
im wondering, rather than try and discover this short and then repair/replace countless crappy connections on a crappy harness would it be better to go through and remove the old one so i can prime paint more completely and then replace it with the complute used harness. the harness i have a line on is from a 73 1.7 which is also a d-jet but im wondering if the computers have different pinouts and such. |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
Sounds like your problem may be with the alternator harness, this is seperate from the FI harness. Take a look at that first. I don't think those FI harnesses are interchangable but you could use the connectors and boots to repair yours. Or better yet get a rebuilt one from Jeff Bowlsby.
Lo-Fi Version | Time is now: 26th June 2024 - 01:40 PM |
