RonnieJ |
RonnieJ ![]() ![]() Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest ![]() |
wondrering if it is possible to put 195-65-15 tire on the stock fuch wheels. Thanks in advance for the info (IMG:style_emoticons/default/smile.gif)
hmeeder |
Dante's Sportscar ![]() ![]() Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 ![]() |
195/65/15 is closer to the original stock tire profile than what most of us are running, so your speedo will be closer to accurate.
I can't remember what the radial equivalent to the original bias-ply size is. For some reason 185/70/15 comes to mind. The taller sidewall will also give you a more compliant ride, if that's what floats your boat. |
Lo-Fi Version | Time is now: 29th June 2024 - 03:41 AM |
