Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Motor is completely apart, just needs to be cleaned....
This is what I have for it so far: ARP "thru-case studs" ARP "head stud kit" (both above item bought from LN Engineering) I also have a new Shadrek(sp??) Type 1 oil pump for it. I know I have to do a few mods to the case for the oil pump, but other than that, what needs to be done. I'm on a strict budget now, so I have to weed thru the wants and needs and pick the more suitible item now. Motor specs: stock bore and stroke (2.0) Flat top pistons (wiating for heads to figure out the compression, but I want in the low 9's) stock 2.0 heads, but I will clean up the ports a little (exhaust ports ceramic coated) FK-10 cam (pretty aggressive cam, but motor will be Megasquirted, so that should be okay) Eurorace Headers (not decided on muffler yet, street car, I don't want it too loud) |
porsche735 |
Member ![]() ![]() Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 ![]() |
So Jake,
What are your thoughts on shufflepinning and/or extra clamping pressure on the case? I know lots of folks have had the same issue we did on the center main. Chris |
Lo-Fi Version | Time is now: 26th June 2024 - 06:14 AM |
