Type 4 Unleashed |
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None ![]() |
The first build, will be a 104.9 x 82 =2835cc
The crank is an DPR 2.0 jrl (1.967") I was going to to have it turned down 1.888" Honda jrls, and use the Lentz rods. Plans changed, I, am now going to use the SBC 327ci 5.7" rod. The rod mods will consist of rod caps off the 250 six cyl chevy rods, mated to the 327ci SBC rods. The big end width of the 6 cyl chevy rod is 1.030, the width of the 327 rod is .940", the width of the 2.0 rod is 1.011". I'll start by having the side of the 327 rod welded to match the width of the six cyl cap. I'll then have the mating surface's of the cap and the rods clearanced enought to re-size the rod from 2.125" to 2.086", which is the bore dia of the Dodge bearing mod, which works on the stock 2.0 ltr jrl (1.967"), same as the dodge. The rods will be notched on the beam end so the bolts can be flipped, the bolts will be 5/16 ARP 2000. And the rod will be re-tanged also for the dodge bearing. The case, |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
There are a few right now that have their underpants on too tight!
(IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:33 AM |
