> Timing Problem?, skipping teeth - how likely ? ?
theman352001
post Jun 23 2006, 09:23 PM
Hello members,
Well, I got the car running.....sort of.
I tried starting it the other day and it seemed close. It also seemed like a car that had the timing just a little off. I had checked the timing before but thought I would experiment this time.
Well, I adjusted the dist. while my dad tried to start the car. After a turn of about 15 degrees, the car started. Throttle response was poor and sounded like the car was getting a bit too much fuel and choking out. I could rev it up though so I was hopefull.
I got the car ready to go for a little trip and she ran fine to the end of the driveway (about 50 yards). But as soon as I got on the road, she bogged down and died. I tried starting it again and got nothing. It just turned over with no hint of firing.
So this has got me wondering if it is possible for the dist. gear to slip on the crankshaft. Any other thougths?
Keith
Mark Henry
post Jun 23 2006, 11:03 PM
that's what I do!
There is no way a dizzy will skip a tooth, unless it's unbolted and popped right out of the hole.
Or I guess if the bolt fell off and the car has the "Men in Black" mod and you're doing warp 5, upside down in the Holland tunnel....
theman352001   Timing Problem?   Jun 23 2006, 09:23 PM
SLITS   Fuel System - Carb, Carbs, D-Jet or L-Jet? How lo...   Jun 23 2006, 10:34 PM
Rand   If the distributor is bolted down properly, it ain...   Jun 23 2006, 10:47 PM
Mark Henry   There is no way a dizzy will skip a tooth, unless ...   Jun 23 2006, 11:03 PM
Bartlett 914   Keith On Dans thread about his exhaust a coment w...   Jun 24 2006, 07:20 AM
Thack   Did you pull out the distributor drive shaft? Coul...   Jun 24 2006, 10:39 AM
Bleyseng
- Lo-Fi Version Time is now: 15th January 2025 - 04:01 AM
