Borderline |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California ![]() |
I've been working on a system to do my own wheel alignment at home in the garage. I'm one csob and this is getting to be a lot of work, but I like to be able to do things myself. The general idea is to use a laser light that points in the same direction of the wheel and reflects back from a mirror in front of the car. If the mirror is square to the centerline of the car, you can see the toe angle in the light reflected from the mirror. Having the mirror several feet in front of the car will make measuring small angles easier. The real problem becomes setting the rear wheels as they must be symetric about the centerline of the car.
To find the centerline of the car I decided to use the wheel mounting surfaces with the car up on....jack stands where it belongs. I dropped a plumb bob from each corner and marked it on the garage floor. Attached image(s) ![]() |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
You could pull my article off the Pelican site and not have to worry about lasers or things like that. It works on both front and rear wheels too. Remember, if you make an adjustment that the car has to be moved, rolled, bounced so the suspension takes the new setting. Also what ever you do, make sure to have you weight in the driver's seat so that it mimics your weight ready to race.
Lo-Fi Version | Time is now: 30th April 2025 - 03:08 AM |
