Neal |
Member ![]() ![]() Group: Members Posts: 300 Joined: 23-April 03 From: Sammamish, Washington Member No.: 605 ![]() |
I have a 220 amp arc welder and oxy/actelyne setup but I would like to know what
a guy needs to have equipment wise to weld on 914 stuff such as body panels...etc I might aslo use this to create garden scuplture. Neal |
John Kelly |
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 ![]() |
Hi Brant,
Glad it was helpful! Getting proper penetration is a function of carrying enough heat. Sometimes you can run pretty hot, and use the welding rod dabbing in and out of the puddle to absorb some of the heat, keeping blow through from happening. Practice! i also dip the torch in and out to control heat. I still look at the back of every weld and sometimes do a little fusion (just the torch, no rod) touch up welding to get good tie-ins and weld areas that did not get enough penetration. John www.ghiaspecialties.com |
Lo-Fi Version | Time is now: 26th June 2024 - 04:51 AM |
