> My SDS EFI install, What, me working on my own stuff? no way
Mark Henry
post Oct 1 2003, 11:26 AM
that's what I do!
My programmer, mixture knob and air/fuel meter.
JeffBowlsby
post Oct 7 2003, 03:04 PM
914 Wiring Harnesses
Mark, that harness doesnt look so bad, it looks like the essentials are there. If you were to simply add an exterior casing to it (heat shrink tubing is best), it would protect the wires from heat and contaminants and make it last much longer. Rubber boots at each component would finish it up and it would be complete.
Will you be posting your programming anytime soon?
Dyno results?
Mark Henry   My SDS EFI install   Oct 1 2003, 11:26 AM
Mark Henry   It's mounted to an old ashtray. I will remove ...   Oct 1 2003, 11:31 AM
Mark Henry   ashtray   Oct 1 2003, 11:32 AM
Mark Henry   TPS mount   Oct 1 2003, 11:33 AM
Mark Henry   TPS on the TB   Oct 1 2003, 11:35 AM
Mark Henry   More pic's to come soon! I have to punch ...   Oct 1 2003, 11:49 AM
Mueller   It's about time you worked on your damn car ...   Oct 1 2003, 12:21 PM
Mark Henry   Where do you get that? Cost? I was just going to ...   Oct 1 2003, 12:43 PM
Jeff Bowlsby   Mark that looks really fine so far. The multi-pin...   Oct 1 2003, 01:13 PM
Mark Henry     Oct 1 2003, 02:17 PM
Aaron Cox   i used to know a place where you could get MIL-SPE...   Oct 1 2003, 03:47 PM
Mark Henry   My crank trigger disk, the magnets 180 apart are t...   Oct 2 2003, 07:59 PM
Mark Henry   on the engine   Oct 2 2003, 08:05 PM
Mark Henry   the sensor mounted   Oct 2 2003, 08:08 PM
Mark Henry   All together now!   Oct 2 2003, 08:11 PM
Mark Henry   The backside   Oct 2 2003, 08:12 PM
Mark Henry   Had to plug the dizzy hole. Cut this off of an old...   Oct 2 2003, 08:14 PM
Mark Henry   I've done it now! Me old 1.8 L-jet. Bye-...   Oct 2 2003, 08:17 PM
Mark Henry   My new JYD 2.0 SDS PEFI engine!   Oct 2 2003, 08:19 PM
Mark Henry   SDS ECU and coil.   Oct 2 2003, 08:24 PM
Mark Henry   How they plug in.   Oct 2 2003, 08:25 PM
Mark Henry   sorry I forgot the pic: the SDS ECU and coil.   Oct 2 2003, 08:30 PM
Mark Henry   The main harness, bit low tech but it is well made...   Oct 2 2003, 08:35 PM
Jeff Bowlsby   Mark, that harness doesnt look so bad, it looks li...   Oct 7 2003, 03:04 PM
Mark Henry   Hi all! :wavey: I doubt if I will get it don...   Oct 28 2003, 11:49 AM
redshift
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 06:40 PM
