Front end clunk |
Front end clunk |
r_towle |
Jun 29 2006, 09:48 PM
Custom Member Group: Members Posts: 24,699 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have been chasing this for several years..mainly when it tart to bug me...
Well im getting annoyed again... My front end Its a 72 car 74 front strut tubes...the original ones were ovaled out at the ball joint hole... I have 23mm front torsion bars 21mm sway bar Bilstein struts. plastic bushings with grease fittings. Ok,,, here is the symptoms. I hit a bump..it clunks...like something is loose. I jacked it up,,removed the sway bar...nothing is loose. I am starting to think that the struts are not sitting all the way into the tube... when I tighten down the "nut" on top of the strut, it does not thread all the way in... In recent fixes... I replaced the strut tubes, brakes, bearings,etc...new rotors and calipers also...had to... I replaced the bushings...twice now..first ones squeeked...did the zirk fittings..all better.. I found that I had no felt pad over the endo f the torsion bars...so I made a rubber on from four rubber washers... Im at a loss.. Do other cars clunk...when hitting bumps??? there is nothing loose in the trunk...btdt... Rich |
Lo-Fi Version | Time is now: 15th January 2025 - 07:00 AM |
