> Front end clunk
r_towle
post Jun 29 2006, 09:48 PM
Custom Member
I have been chasing this for several years..mainly when it tart to bug me...
Well im getting annoyed again...
My front end
Its a 72 car
74 front strut tubes...the original ones were ovaled out at the ball joint hole...
I have
23mm front torsion bars
21mm sway bar
Bilstein struts.
plastic bushings with grease fittings.
Ok,,,
here is the symptoms.
I hit a bump..it clunks...like something is loose.
I jacked it up,,removed the sway bar...nothing is loose.
I am starting to think that the struts are not sitting all the way into the tube...
when I tighten down the "nut" on top of the strut, it does not thread all the way in...
In recent fixes...
I replaced the strut tubes, brakes, bearings,etc...new rotors and calipers also...had to...
I replaced the bushings...twice now..first ones squeeked...did the zirk fittings..all better..
I found that I had no felt pad over the endo f the torsion bars...so I made a rubber on from four rubber washers...
Im at a loss..
Do other cars clunk...when hitting bumps???
there is nothing loose in the trunk...btdt...
Rich
post Jun 29 2006, 11:06 PM
Resident German
QUOTE(r_towle @ Jun 29 2006, 08:48 PM) *
have you pulled your tank lately? i had the same thing, clunk when going over bumps. when i pulled the tank a few weeks ago, i could see the marking on the bottom where it would hit the swaybar ...
the swaybar "bends" when under load and if it's a tight fit, it'll hit the bottom of the tank. that was my clunk ...
my solution will be to move the tank just a tad higher (using the rubber holddown thinggies) ...
just make sure your fillerneck doesn't hit the hood when closed ...
(IMG:style_emoticons/default/smile.gif) Andy
r_towle   Front end clunk   Jun 29 2006, 09:48 PM
- Lo-Fi Version Time is now: 15th January 2025 - 06:38 AM
