r_towle |
Brad,
I will deliver you a chassis all modified, ready to go with an original six engine mount, cage and rough body work complete. I want you to find, install, tweek, road test, and finish the following 3.6 motor /6 G50 tranny with limited slip bigger axles and CV joints (you spec) cable shifter Engine management (original kit for the 3.6) Front mount oil cooler (I will leave the size up to you, basically I will cut the front bumper and add the lower GT valance) What else?? Body and interior I will take care of as well as the cage, though I could be convinced to let Tony do it while its there, otherwise I may stick with Chris because he is close enough for me to go down there, and I want to do a few un conventional things here. then I will come get it. So, no shipping for you, just find and install the basic list above. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Just sign him a blank check and he'll fill in the amount. (IMG:style_emoticons/default/laugh.gif)
Paul |
Lo-Fi Version | Time is now: 26th June 2024 - 05:27 AM |
