> Unknown Wire 1974 1.8 L-Jet Double Relay
jwilliamadams
post Jul 1 2006, 06:27 PM
Will Adams
1974 1.8 L-Jet
There is a single yellow wire from the fuel injection double relay to the engine relay panel and it plugs into one of the terminals of the quad connector on the panel. See the attached picture. I think I have it plugged onto the correct terminal of the quad.
Can someone with a 1.8 L-Jet take a look at their relay panel and see if their single yellow wire is plugged onto the same terminal as mine?
Wiring diagram is useless. Is just indicates that the yellow plugs into the quad connector on the relay panel. It does not indicate which terminal.
Thanks!
jwilliamadams
post Jul 1 2006, 07:05 PM
Will Adams
Thanks Grasshopper!
jd66921
post Jul 1 2006, 07:15 PM
QUOTE(jwilliamadams @ Jul 1 2006, 06:05 PM) *
Thanks Grasshopper!
Maybe someone can explain the wiring on a '75 1.8 to me then.
I have a white wire coming out of the 12 pin connector bundle that connects to the
four pin connector, but the next pin over. Also, I do not have a power supply
relay, or a fuel pump relay. This does not seem right to me, but then I do not
understand any of this. My fuel pump runs all the time, and does not shut off after
a few seconds. Is this a fuel pump issue, or a relay issue?
Grasshopper, anyone??
jwilliamadams   Unknown Wire 1974 1.8 L-Jet Double Relay   Jul 1 2006, 06:27 PM
grasshopper   well, I couldn't find a picture, but yes, that...   Jul 1 2006, 07:03 PM
jwilliamadams   Thanks Grasshopper!   Jul 1 2006, 07:05 PM
jd66921
- Lo-Fi Version Time is now: 21st December 2024 - 11:55 PM
