> Turn Signal indicators, 2 instead of 1
John
post Mar 4 2006, 09:36 AM
member? what's a member?
Has anyone rewired a later model car to that of an early model car to get individual turn signal indiators?
The early style was wired so that each indicator light (in the tach) had one of the turn signal wires (black/white stripe or black/green stripe) and the blue/white stripe.
As far as I can tell, the flasher relay is the same, but the wiring is different due to the fact that the 1974 and later cars only had the single indicator light in the tach. The 74 wiring diagram shows the indicator light wired to the blue/white stripe and ground.
Is this rihgt or not.
maybe I'll wire it up and find out.....
jim_hoyland
post Jul 12 2006, 11:18 AM
Get that VIN ?
The Saabs sound good; would you have the part number(s). I'll prolly order them now and do the install much later. Can they be ordered on-line ?
Thanks again,
Jim
JOHNMAN   Turn Signal indicators   Mar 4 2006, 09:36 AM
bd1308   http://www.914world.com/bbs2...   Mar 4 2006, 09:45 AM
Bartlett 914   I have a 75. I was able to do what you wanted. If ...   Mar 4 2006, 02:45 PM
jk76.914   I figured this out. Do you guys still need to kno...   Jul 6 2006, 12:44 AM
double-a   i did this. not hard, just need to run a new wire ...   Jul 6 2006, 08:07 AM
BigDBass   :popcorn: I would like to know the secret.   Jul 6 2006, 11:27 AM
914MF   :boing: :boing: Yes, please tell us. :help: :not...   Jul 6 2006, 12:11 PM
jim_hoyland   I seen a late model with the turn signal indicator...   Jul 6 2006, 01:24 PM
jim_hoyland   :popcorn: ...   Jul 6 2006, 03:53 PM
jk76.914   Hi Folks, well I'm back at it. I will go thro...   Jul 6 2006, 10:45 PM
jk76.914   All right. Back again. Here's the schematic ...   Jul 6 2006, 11:35 PM
bd1308   :) thx   Jul 6 2006, 11:51 PM
JOHNMAN   I found the answer several months ago in UpFixin v...   Jul 7 2006, 12:30 AM
BigDBass   Thanks for the excellent description.   Jul 7 2006, 06:53 AM
Lawrence   I nominate this thread for Classic Status! Ch...   Jul 7 2006, 08:51 AM
tdgray   2nd :thumbsup: Very good write up. Very detaile...   Jul 7 2006, 11:41 AM
jim_hoyland   Good description; would you mind adding a few word...   Jul 10 2006, 09:07 PM
JOHNMAN   Jim, You would add two wires from the emergency f...   Jul 11 2006, 01:13 AM
jk76.914   That's right. I didn't want to pull out ...   Jul 11 2006, 08:28 AM
jim_hoyland   Thanks for the installation detail--makes sense to...   Jul 11 2006, 08:47 AM
jim_hoyland   One last question; do the repeater lights ground t...   Jul 11 2006, 09:39 PM
jk76.914   That's right. Just like the front and rear si...   Jul 12 2006, 07:18 AM
jim_hoyland   The Saabs sound good; would you have the part numb...   Jul 12 2006, 11:18 AM
nivekdodge   Wow someone else had to do this   Aug 6 2022, 10:06 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th January 2025 - 08:19 AM
